Ratsun Forum
Go Back   Ratsun Forum > Write-ups > HowTo
Reply
Thread Tools Display Modes
  #201
Old 10-28-2009, 09:03 PM
sycloned916's Avatar
sycloned916 sycloned916 is offline
Vehicles: 1991 GMC Syclone, 1967 Datsun SR Powered 520 PU
sycloned916 is on a distinguished road
Default
Quote:
Originally Posted by lil89ram50 View Post
hey guys new here but i got a 1995 s-14 ka24de engine and wiring and ecu and wana put it in my 85 720 would you guys be able to draw out a quick diagram? and also, im kinda confused on the ecu's, would i need to keep my stock one along with the ka?
Diagram you would need should be on the first few pages pretty easy to follow.
The ECU's if it does have one?? not to sure on that yr but the KA ecu would replace it,you should have a ka in it? I dont think it would be needed for anything else,like the lights.The KA ecu will now run the engine.I wouldn't toss it if you do it just in case!
__________________
1967 SR520 PU
aka Tha Beast!
9psi!
1991 GMC Syclone #2414
AWD 4.3L V6 Turbocharged
  #202
Old 11-02-2009, 11:33 AM
71ka510 71ka510 is offline
Vehicles: 71 4-door 510, 2006 scion xb
71ka510 is on a distinguished road
Default
well i never heard of the 720 having a ka... z20 , z22 and z24 was as new as they got i thought.... which were carbed , pretty sure only the z20 from the 200sx had efi..... ka came in the 240sx,stanza , axxess d21 hardbody and the frontier....
so OP, what engine does this 720 have? 1985 720 had z20 (carb) z24 (carb) or the sd25 (deisel)
  #203
Old 11-02-2009, 03:25 PM
lil89ram50 lil89ram50 is online now
Hall Monitor
lil89ram50 is on a distinguished road
Default
im guessing you refering to me? lol
what i started with, 1984 2wd 720, z24, 5sp
what i just got for it, 1995 240sx ka24de engine with wiring
so you are correct, they did not come with the ka's from factory....... you have any advice on the wiring?
alls i want is a simple toggle switch and a push button...... very basic, and i want all emissions removed, will be making a block off plate for my egr tonight
  #204
Old 11-03-2009, 09:17 AM
Default
well , just follow the diagram on the first page..... as for smog removal..... i have a sohc but correct me if i am wrong..... same smog crap ..... egr, secondary butterfly valves, excessive vac lines, can all be removed.... this page helped me with my sohc......http://ka24et.com/diys/SOHCemissions/emissions.html
  #205
Old 11-07-2009, 07:01 PM
bsd510wag bsd510wag is offline
Hall Monitor
bsd510wag is on a distinguished road
Default
ok i just want to thank icehouse so much i got my sr running today after hooking everything up it kicked right over no problem this is an easy thing to flow im 20 and i never ever worked with car wiring i just want to thank you again
  #206
Old 11-08-2009, 08:02 AM
Jacobszabo's Avatar
Jacobszabo Jacobszabo is offline
Hall Monitor
Vehicles: 1982 Datsun 210
Jacobszabo is on a distinguished road
Send a message via AIM to Jacobszabo
Default KA24e ECU pinout?
searched around ratsun and the internet and couldnt find it, im not the greatest at wiring and i just got a 72 510 wagon with a ka all i have to is wire it
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Copyright © 2007-2008, Ratsun.net
