Ratsun Forum
Go Back   Ratsun Forum > Technical > Brakes
Reply
Thread Tools Display Modes
  #1
Old 07-02-2009, 08:13 PM
dat521gatherer's Avatar
dat521gatherer dat521gatherer is offline
Vehicles: 2 521's 2 jetta's 75 monarch 77 hornet cb650
dat521gatherer is on a distinguished road
Default biggest jackass ever!
10+ years later i now know why my 72 521 doesn't stop after several brake jobs. it never stopped correctly after i did my king pins. hint hint. i always thought this might be the problem but never looked at it due to laziness i guess. the part that pisses me off is not only am i a jackass but so are the shops that looked at it and they get paid for that shit.
MY FUCKING HUBS ARE ON BACKWARDS!!!
i'm guessing this will fix my problem. i kept telling everybody it stops on a dime when going in reverse. i win the jackass of the decade award for this one. hell i almost got rid of my truck a few times cause it wouldn't stop.
__________________
up the irons!!!!!
  #2
Old 07-02-2009, 08:15 PM
Gary's Avatar
Gary Gary is offline
Member
Vehicles: P510, JZX83, UCF11, N13
Gary is on a distinguished road
Default
bahaha good work
i have quite a lot of those moments
__________________
P510
  #3
Old 07-02-2009, 08:20 PM
Default
you wouldnt believe the relief i feel just knowing all i need to do is swap sides. my plan a was to take the whole brake system including the lines off my 71 and put them on my 72. my 71 is the daily beater mind you. then buy the whole system out of the yard and put it on my 71. probably why i never got around to it.
__________________
up the irons!!!!!
  #4
Old 07-02-2009, 08:44 PM
datzenmike's Avatar
datzenmike datzenmike is online now
KING RAT
Vehicles: One '78 KC, two '82 200sx (parts)did own '68 510, '76 B210 (new), '71 521
datzenmike is on a distinguished road
Default
This is why the leading and trailing brake shoes mustn't be swapped. Those shops should have noticed the shoes were in the wrong positions.
__________________
RUST NEVER SLEEPS Plenty Of Time For Sleep In The Grave
Quote:
Originally Posted by Skib View Post
Plus I will make fun of anything and everything, just because I can
  #5
Old 07-02-2009, 10:03 PM
yello620's Avatar
yello620 yello620 is offline
Vehicles: 76 620, 76 FJ40, 68 Chev swb, 92 K2500 suburban, 03 mercedes C240(wifes)
yello620 is on a distinguished road
Default
I am betting that this isnt so much of a problem with the shoes on the wrong sides as it is a much bigger problem with the backing plates being on the wrong sides and the wheels cylinder is then backwards. The piston now only works good in reverse.
When they are all installed correctly, they don't stop worth a damn in reverse.
However, Disc brakes solve both of these problems.
__________________
76 620, L20b, 4spd, weber, D21 V-6 front disc brakes, 3.90 rear gears, Factory 79 intermittent wipers.
Jason
  #6
Old 11-07-2009, 12:57 AM
Default
done deal. the dog bones were on the correct side. the spindles with backing plates and wheel cylinders were pointing in the wrong direction.
left side came apart easy
right side king pin was seized in the dog bone and i had to take it to the machine shop and before i knew it i had to do the king pins again. oh goody.
good thing i had a spare new king pin set cause they're getting hard to find.
stops great now.
__________________
up the irons!!!!!
  #7
Old 11-09-2009, 09:53 AM
banzai510(hainz)'s Avatar
banzai510(hainz) banzai510(hainz) is offline
L motor God
banzai510(hainz) is on a distinguished road
Default
I replaced my Kingpins and one day the steering was hard. Find out one side started seizing up.
Datsunmike and Mklotz suggested heating it up with a torch and I shot new grease in there and it was fine after I worked it abit.
Rockauto had Kingpin sets. its the 11mm threaded wedge that getting hard to come by.
__________________
Throw on some Weber sidedrafts, Rising Sun hood.... call it good
  #8
Old 11-09-2009, 12:15 PM
zuum510's Avatar
zuum510 zuum510 is offline
zuum510 is on a distinguished road
Default
__________________
*Disclaimer*
The opinions in the above post, may or may not be shared by other members of this forum... also I may or may not be serious.
That doesn't mean its untrue!
Quote:
Originally Posted by datzenmike View Post
To retard you will need to turn it counter clockwise.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Copyright © 2007-2008, Ratsun.net
