Ratsun Forum
Go Back   Ratsun Forum > Technical > Suspension
Reply
Thread Tools Display Modes
  #1
Old 08-09-2008, 07:07 PM
SRSANDS's Avatar
SRSANDS SRSANDS is offline
Man of a thousand questions
Vehicles: 70 4 door dime, 2000 Toyota Tundra
SRSANDS is on a distinguished road
Default 280zx strut swap
So I picked up my 280zx struts tody. Started the spring perch swap and wanted to ask a few questions. With the 280zx strut how far lower did you place the 510 perch than the original stock z perch? I have lowering springs in there also so I am curious if anyone has done the swap with lowering springs and where to weld the lower perch......it seems to me that one to one and a half inches should be good and still clear the tire. What rim and tire combo are you running to clear this set up also would help? Thanks
  #2
Old 08-09-2008, 07:39 PM
DISLEXICDIME's Avatar
DISLEXICDIME DISLEXICDIME is offline
Vehicles: 71 and 72 4 door 510 86 conquest tsi 87 conquest 88 starion shp
DISLEXICDIME is on a distinguished road
Default
how low are you going?
__________________
Quote:
Originally Posted by DISLEXICDIME View Post
i thought this was a car forum ? i liked it better when there where car guys on here that talked about cars !
http://www.myspace.com/dislexicdime
http://forum.ratsun.net/showthread.php?t=402
http://forum.ratsun.net/showthread.php?t=5699
I WISH I HAD A Z18
  #3
Old 08-09-2008, 09:29 PM
SRSANDS's Avatar
Default
Well, it had lowering springs in the stock struts. Removed the perch and welded one and a half inches lower than the stock zx perch. With that relocation, the diffrence in the strut length, an the springs being techniques lowering springs should be nice and low. Dont have any test riims to fit but im thinking I would be able to run any bigger and 15's without tire rubbing the perch
  #4
Old 08-10-2008, 08:56 AM
Icehouse's Avatar
Icehouse Icehouse is online now
wolf man
Vehicles: 59 1000 4 door - 2 68 510 2 door - 71 1200 sedan - 78 620 kc 4x4 - 89 S13 coupe
Icehouse is on a distinguished road
Send a message via AIM to Icehouse
Default
Shawn you gotta make sure you always say ZX struts, the Z and ZX are way different I guess in your case strut hehe
__________________
“If you don’t follow your dreams, you may as well be a vegetable” - Burt Munroe
  #5
Old 08-10-2008, 11:44 AM
SRSANDS's Avatar
Talking
Thanks ice....my mistake...I get a little confused when I pull up images of the Z and the ZX they look the same.....hope I got the right ones!!!! The rotors are slotted on the edges.....are they the right ones and whats the diff between the two. I will be grabbing the other one tommorow that sucked.....rip offs. I am going to undo the calipers and use my 13 inch wheels when I am done just to see the stance! Thats after I order the new strut cartridges darn it cant wait
  #6
Old 08-10-2008, 10:10 PM
zuum510's Avatar
zuum510 zuum510 is offline
zuum510 is on a distinguished road
Default
with 195/50/15 or bigger you will run into clearance problems unless you do coilovers...
__________________
*Disclaimer*
The opinions in the above post, may or may not be shared by other members of this forum... also I may or may not be serious.
That doesn't mean its untrue!
Quote:
Originally Posted by datzenmike View Post
To retard you will need to turn it counter clockwise.
  #7
Old 08-11-2008, 04:38 PM
SRSANDS's Avatar
Default
Thanks zuum510, I like the front of your wagon, what do you have setup in there?
  #8
Old 08-11-2008, 10:13 PM
zuum510's Avatar
Default
lol thats not mine, just one of my favs. thats a bagged wagon from japan.
I did the 280zx struts in my first wagon with some accord coilover sleeves, I welded on a steel ring for it to sit on and it was a good setup, total I spent with new pads (didn't need rotors or bearings) with the coilovers was roughly $240 on the road... on my second wagon I used 280zx struts and cut them in half then welded on some 240sx S13 FULL coilovers with 24way adjustable damping, adjustable spring preload, and serperate adjustable ride height... I bought the coilovers second hand and paid $500 for those (believe me that a good deal) and on the road price was about $700. I tested them but took them off and they got sold to a guy in arizona.
YOu "might" get away with an inch off drop by lowering the spring perch but thats a maybe... wider wheels will make this more difficult, best part of the 280zx swap is you GAIN half in more fender clearance on each side so deeper offset wheels are GREAT idea, and THEN you may get more drop with the spring perch. Its your car bro, but if your gonna go through all this hassle you should just order up a set of the weld on ground controls in the spring rate you like.
__________________
*Disclaimer*
  #9
Old 08-14-2008, 04:06 PM
SRSANDS's Avatar
Default
Thanks man for the info...I am gonna order GC set up next week...not too thrilled now as you can read my post in the Junkyard Woes post....only have one 280zx strut right now
  #10
Old 08-19-2008, 09:46 PM
devilduece devilduece is offline
Member
Vehicles: 76 620 sb 72 510 goon 88 4x4 suburban 82 corolla slammed to the nuts
devilduece is on a distinguished road
Default
when pulling the struts what all do i need for my goon?
  #11
Old 08-19-2008, 09:47 PM
Member
Default
maybe a picture might help im a very visual person
  #12
Old 08-19-2008, 09:52 PM
zuum510's Avatar
Default
DD just take the whole thing minus the steering knuckles... you don't need the top hats or the spring or spring perch but those are hard to remove in the wrecking yard... take the soft brake lines also...
__________________
*Disclaimer*
  #13
Old 11-05-2009, 07:17 AM
murderwagon murderwagon is offline
Member
Vehicles: 1970 dime wagon, jeep ,1971 240z
murderwagon is on a distinguished road
Send a message via AIM to murderwagon
Default brakes
if you ware doing a zx sturt conversion are you swaping the brakes also if so 13inch wheels will not fit over the caliper
  #14
Old 11-05-2009, 07:55 AM
thisismatt thisismatt is offline
thisismatt is on a distinguished road
Send a message via AIM to thisismatt
Default
Quote:
Depends on the wheels. Some 13" will fit, some will not.
I would take the ZX knuckles with the struts. You likely won't get charged for them and they're shorter than stock 510, so you may want to use them, or sell them on ebay.
__________________
Been around the world and found
That only stupid people are breeding
The cretins cloning and feeding
And I don't even own a TV
  #15
Old 11-05-2009, 04:02 PM
71ka510 71ka510 is offline
Vehicles: 71 4-door 510, 2006 scion xb
71ka510 is on a distinguished road
Default
if you keep the zx upper mounts, and cut the diamter as small as the stock 510's when mounted they put th car about an 1" lower than stock ..... but you have to use coilovers.....
  #16
Old 11-07-2009, 06:29 PM
JDM510's Avatar
JDM510 JDM510 is offline
Vehicles: 1971 Datsun 510 2dr
JDM510 is on a distinguished road
Default
i heard the zx strut come if diff spindal angles soo if you only have one make sure you get a match
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Copyright © 2007-2008, Ratsun.net
