Ratsun Forum
Go Back   Ratsun Forum > Technical > Engine
Reply
Thread Tools Display Modes
  #1
Old 11-03-2009, 06:01 PM
jfbrink jfbrink is offline
Hall Monitor
Vehicles: '66 Datsun Roadster, '67 Datsun 411 SSS, '07 Honda Fit
jfbrink is on a distinguished road
Default Have A14 engine ID, need car Model/Year
Hi,
An A14 engine came loosely fitted in my 411. Since I have it, I'm going to try to get it running and installed. This would be easier, for parts counter clerks and myself, if I knew what Model/Year this engine is specifically from.
The engine ID # is A14-708268.
The one Internet resource I found indicated that this would have come from a 1975 Datsun B-210. Can anyone confirm or deny this information?
Thanks,
Jesse.
  #2
Old 11-03-2009, 06:32 PM
DRIVEN's Avatar
DRIVEN DRIVEN is offline
Vehicles: '71 1200 coupe (with matching parts car), 2-'72 510 wagons, +8 non-Datsuns
DRIVEN is on a distinguished road
Default
I cannot confirm or deny but the only real differences when ordering parts will be the intake/exhaust gasket. A14 was available with either round or oval intake ports. All the other gaskets, bearings, tune-up parts should be the same no matter the year. Carb kits may vary but could be orders by carb numbers. Maybe someone will correct me if I'm wrong.
__________________
Is it madness or is it genius?
  #3
Old 11-03-2009, 06:37 PM
datsunaholic's Avatar
datsunaholic datsunaholic is online now
Vehicles: Not quite the whole set yet
datsunaholic is on a distinguished road
Default
While the engine serial number might be helpful if the internals changed, they didn't so it's not really useful except for smog parts, and the above mentioned manifold gaskets. Someone could have swapped earlier or later parts on externally. The A14 was used from 1975-1982 in the US. I'd be fairly certain it's from either a 75-78 B210 or a 79-82 210. Can narrow it down some by knowing what kind of distributor it has- points or EI, matchbox EI or remote ignitor (I think there was a remote ignitor A-series dist... need to check mine)
__________________
Well, at least he gets 24 hours notice. That's more than most of us get. All most of us get is, "Mind that bus!" "What bus?" _splat_!
  #4
Old 11-03-2009, 06:38 PM
datzenmike's Avatar
datzenmike datzenmike is offline
KING RAT
Vehicles: One '78 KC, two '82 200sx (parts)did own '68 510, '76 B210 (new), '71 521
datzenmike is on a distinguished road
Default
I have a source that lists the '75 model year 2 door, 4 door or coupe 'car number' as fitting between 510001 and 710000. Not known if the number stamped on the block matches the 'car number'.
__________________
RUST NEVER SLEEPS Plenty Of Time For Sleep In The Grave
Quote:
Originally Posted by Skib View Post
Plus I will make fun of anything and everything, just because I can
  #5
Old 11-06-2009, 07:10 AM
kurt appley kurt appley is offline
Hall Monitor
kurt appley is on a distinguished road
Default
We know that heads, intake's and distributors did change. Can anyone tell me if cams changed? If not a late low power A14 should be able to become the high power B210 engine with nothing more than a head change. Anyone????
Tnx, Kurt.
  #6
Old 11-06-2009, 11:23 AM
DRIVEN's Avatar
Default
According to this:
http://datsun1200.com/modules/mediaw...title=Camshaft
Cams could be the same or different depending on the year or market.
There is head info here:
http://datsun1200.com/modules/mediaw...Cylinder_Heads
__________________
  #7
Old 11-07-2009, 06:39 AM
Hall Monitor
Default
Thanks Driven, I've checked those sites but they don't specifically say whether there was a change between the high power B210 A14 and the low power economy A14. Probably best to get ahold of my local Nissan dealer.
Tnx, Kurt.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Copyright © 2007-2008, Ratsun.net
