Ratsun Forum
Go Back   Ratsun Forum > Technical > Brakes
Reply
Thread Tools Display Modes
  #1
Old 10-27-2009, 01:18 PM
521newbie 521newbie is offline
Hall Monitor
Vehicles: 71' 521
521newbie is on a distinguished road
Default Disk brake conversion 521
I am getting the parts together to do the front disc swap on my 521.
I have the following:
Lower control arms
rotors, calipers, soft lines, spindles, hubs
Custom upper arms (on their way from beebani)
SAE to Metric brake line adapters
Pads
upper arm bushings
A couple questions.. Can/should I use the stock master cylinder, if not what should I use?
I want to make sure I'm not missing anything. This is my daily driver and I can't be down too long. Much thanks for the help.
  #2
Old 10-27-2009, 04:31 PM
yello620's Avatar
yello620 yello620 is offline
Vehicles: 76 620, 76 FJ40, 68 Chev swb, 92 K2500 suburban, 03 mercedes C240(wifes)
yello620 is on a distinguished road
Default
I would not even consider running the single outlet master cylinder on it with the conversion. They are marginal when with the drum system, the seals are almost guaranteed to fail when you increase the needed master cylinder piston stroke due to the larger fluid capacity calipers.
The replacement master cylinder is going to depend on a couple of things. Are you going to try to get a power booster on it too?
I would probably consider the 7/8" bore 280z master cylinder for non-power brakes. If you are going to install a power booster then i would consider the 15/16" bore master cylinder from a 79/80 280zx.
Even at that, i dont think that either of these are a direct bolt on deal to the 521, but must have mount holes filed to make it fit(i think).
__________________
76 620, L20b, 4spd, weber, D21 V-6 front disc brakes, 3.90 rear gears, Factory 79 intermittent wipers.
Jason
  #3
Old 10-27-2009, 05:03 PM
DRIVEN's Avatar
DRIVEN DRIVEN is offline
Vehicles: '71 1200 coupe (with matching parts car), 2-'72 510 wagons, +8 non-Datsuns
DRIVEN is on a distinguished road
Default
We did the Klotz conversion on my brother's 521 which uses 720 rotors/calipers. Used '79 280zx master. Had to open up the mounting holes on the master cylinder and modify the push rod. It works great.
__________________
Is it madness or is it genius?
  #4
Old 10-28-2009, 01:29 PM
Hall Monitor
Vehicles: 71' 521
Default
Do you mean the holes on the firewall need opened? How was the pushrod modified? Does the hardline fitting need modified to fit the new master cylinder?
  #5
Old 10-28-2009, 02:01 PM
DRIVEN's Avatar
Default
The posts on the firewall and the holes in the master cylinder were slightly off. I used a file to elongate the holes. The 521 push rod is "captured" and needs to be pulled off by removing the wire clip at the end of the bore. The mushroom end needs to be cut off and round stock material needs to be welded to the end.
Because the original master cylinder is a single pot style you will have to modify the hard lines. The front lines need to be separated from the rear lines. You should also consider adding an adjustable proportioning valve for the rear.
__________________
  #6
Old 10-28-2009, 06:20 PM
AtomChurch's Avatar
AtomChurch AtomChurch is offline
150 points
Vehicles: 1972 510; 1970 521
AtomChurch is on a distinguished road
Default
Quote:
I understand that this is recommended, but is it necessary ? I will eventually do this swap and I am wondering if I should get a valve before hand or just get one when the opportunity comes up. How much more pressure do the disc brakes need?
__________________
"That bolt? Ah nah, you don't need that bolt. It's an extra. Just throw it in a jar and save it for later."
"Its a datsun thing."
"Sounds like edward scissorhands stuck his hands in a wood chipper " -DirtyLt1
  #7
Old 10-29-2009, 09:44 AM
DRIVEN's Avatar
Default
Might not be necessary. These trucks are really light in the back so the prop valve just allows you to reduce the amount of braking to the rear drums which avoids lockup. I'm sure you can get away without it but they only cost $40. It's not really a matter of pressure as much as balance.
__________________
  #8
Old 10-29-2009, 01:27 PM
Hall Monitor
Vehicles: 71' 521
Default
By separate the lines, do you mean I add a line from the master to where they fork off to front and back? Can I add the proportioning valve to that junction for the rears?
If anyone has pictures or a diagram it would be a big help... Thanks for the info so far..
  #9
Old 10-30-2009, 08:30 AM
DRIVEN's Avatar
Default
There is a T on the frame rail. The quick and dirty way is to disconnect the rear line from there and plug the port. Then run a line from the new master cylinder down and connect it with a male-to-male coupler. If you add a proportioning valve, it goes in that line.
__________________
  #10
Old 10-30-2009, 11:07 AM
Hall Monitor
Vehicles: 71' 521
Default
I get it now. Thanks for the description. I'll do that.
  #11
Old 10-30-2009, 01:36 PM
Hall Monitor
Vehicles: 71' 521
Default
Does anyone know where I can find a non-power brake master cylinder? Everyone I call only has the power master cylinder.
Thanks..
  #12
Old 10-30-2009, 02:00 PM
Hall Monitor
Vehicles: 71' 521
Default
I'm confused. That's a picture of my stock master cylinder. The picture on rock auto doesn't say if it's for non-power and I don't see any rod/seal in the picture.
  #13
Old 10-30-2009, 02:08 PM
Hall Monitor
Vehicles: 71' 521
Default
Please read from my OP. I am putting disks on my 521. I was told I could use a brake master cylinder from a 76 280z with non-power. I can't find that part anywhere and I'm wondering what I should be looking for...
  #14
Old 10-30-2009, 03:30 PM
DRIVEN's Avatar
Default
I'm not aware of any Zs that were available without power brakes.
__________________
  #15
Old 10-30-2009, 05:48 PM
Hall Monitor
Vehicles: 71' 521
Default
Where can I get the non-power master???
  #16
Old 10-31-2009, 12:58 AM
yello620's Avatar
Default
What you need is a master cylinder for the Z. Your only option is from a power brake vehicle that you will be using in a manual brake application. You are simply deleting the power booster from the system. This is also why the pushrod needs modified.
__________________
Jason
  #17
Old 11-01-2009, 05:18 PM
Hall Monitor
Vehicles: 71' 521
Default
Is there a pushrod in it? The picture doesn't have one at all.
  #18
Old 11-01-2009, 07:52 PM
DRIVEN's Avatar
Default
Probably not. You'll have to modify the 521 push rod.
__________________
  #19
Old 11-01-2009, 09:20 PM
kaliboy96's Avatar
kaliboy96 kaliboy96 is offline
Hall Monitor
Vehicles: 1969 Datsun 521, 2006 Cadillac STS
kaliboy96 is on a distinguished road
Default
can you eloborate on the modification of the pushrod, I used a 280zx master cylinder as well and it makes a wierd clicking noise when I depress the pedal what kind of modification is necessary and do you have photos
  #20
Old 11-01-2009, 10:24 PM
mklotz70's Avatar
mklotz70 mklotz70 is online now
Beelzebub
Vehicles: '64 NL320, '69 510 wgn, '70 521(wife's), '72 521(daughter's)
mklotz70 is on a distinguished road
Default
this link will get you fairly close. You may need to back up or go forwards a bit depending on whether you're logged in at the time.
About 3/4 down the page...the m/c stuff starts.
http://forum.ratsun.net/showthread.php?t=10314&page=7
If I remember right...it's a '79 280zx m/c you want....it was disc/drum. Yello620 may correct me on that...I know I got it wrong last time
__________________
Don't have to be too bright to be me!!
  #21
Old 11-02-2009, 11:44 AM
Hall Monitor
Vehicles: 71' 521
Default
Does that mean I need to take the pushrod out of the stock master and put it into the 280 master? From what I understood, just needed to weld the end from the stock master to the 280 master. Is that right?
  #22
Old 11-03-2009, 03:51 PM
kaliboy96's Avatar
Hall Monitor
Default
I checked out the thread, is it really necessary to make this modification, I think mine will work okay without modification. But I am not sure why its clicking.
  #23
Old 11-03-2009, 05:29 PM
DRIVEN's Avatar
Default
You won't be welding anything to the ZX master. Just extending the 521 push rod.
__________________
  #24
Old 11-03-2009, 09:22 PM
mklotz70's Avatar
Beelzebub
Default
climb under the dash...pull back the rubber boot and watch the linkage as you press the brake pedal....most likely, the ticking is either a worn pin on the clevis, or it's the mushroom end moving in the m/c..........because it's not designed to fit there.
__________________
  #25
Old 11-04-2009, 01:13 PM
Hall Monitor
Vehicles: 71' 521
Default
I'm still not getting it. What exactly am I doing with each master cylinder?
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Copyright © 2007-2008, Ratsun.net
