Ratsun Forum
Go Back   Ratsun Forum > Technical > Suspension
Reply
Thread Tools Display Modes
  #1
Old 10-28-2009, 09:28 PM
murderwagon murderwagon is offline
Member
Vehicles: 1970 dime wagon, jeep ,1971 240z
murderwagon is on a distinguished road
Send a message via AIM to murderwagon
Default 510 wagon rear spring rate
i need to know the stock 510 wagon rear leaf spring rate and where to find the addco rear sway bar kit thanks
  #2
Old 10-28-2009, 10:02 PM
benzo's Avatar
benzo benzo is offline
Vehicles: 71 wagon/71 Blazer
benzo is on a distinguished road
Default
not sure on the rate but I believe I have seen a posting of 180 or 200 lbs. I am sure someone can post more exact numbers.
as for the bar you can call addco direct and get it, I have the addco bar and got the hardware from them.
  #3
Old 10-29-2009, 01:31 AM
Member
Default h
how does it handle big improvement ? i am doin a whole suspension build and i am gonna have springs made for the rear fat sway bar in the front as well as coilovers up there but not quite sure about the rear yet
  #4
Old 10-29-2009, 11:08 PM
benzo's Avatar
Default
Yes it was a nice upgrade. I was lucky and got it off a guy local to me for cheap and addco was nice to send me new hardware free just pay shipping. I can tell you one thing about wagons but most cars in general. don't lower it a lot unless you plan on making mods to the chassis. I lowered mine 2" out back with blocks and can tell you don't go lower unless you mod the chassis to avoid rear end knocking and driveshaft knock. I will be adding a panhard bar as I feel that would help a lot for not a lot of money or mods.
I live in san francisco and roads here are not good hence that is why I did not lower it a lot but maybe your area may be nicer road wise. I am sure you have read a lot of the mods people have done to enhance handling. you can do a lot of mods for cheap. I literally found a lot of items at the junkyard for cheap or free or on craigslist or ebay from people clearing out space. I think the only thing I paid for was new shocks for front and I even got a good price on those. If you need coil overs and tokico shocks I can offer them.
  #5
Old 10-30-2009, 12:11 AM
Member
Default definitly
i blocked the back 2 inch and i like the height. perfect for me .i would definitely be interested in some coil overs and tockicos can you give me a price list and some spring rate choices thanks a lot
  #6
Old 10-30-2009, 12:37 PM
benzo's Avatar
Default
are you going to be using zx struts and brakes or stock brakes and struts?
  #7
Old 10-31-2009, 12:55 PM
Member
Default dont know
i am still pondering the question what is your suggestion
  #8
Old 10-31-2009, 02:12 PM
benzo's Avatar
Default
I personally would get the zx front brakes and struts. easy mod and cheap, for me at that time I got lucky and got my set up almost for free from a junk yard. just had to clean it up, resurface rotors, re pack bearings and change seals and get brake pads. I also got bump steer spacers and it all came together well. no negative camber. tire wear is even and stable on freeway given I pretty much changed all other parts like ball joints and tie rods and bushings. car feels good considering it is 38 years old.
  #9
Old 11-02-2009, 06:23 PM
Member
Default sensa trac
thouse sensatac monroe shocks with the coil spring around them are they worth it i was debating having rear springs made but i want to get the best bang for the buck and i am building the whole car every aspect so i want to have everything done with out spending a million dollars
  #10
Old 11-02-2009, 07:40 PM
benzo's Avatar
Default
never tried those sensatracs but if the springs are like a helper I do not see anything majorly wrong with using them. do they state the rate of the springs?
  #11
Old 11-03-2009, 07:26 PM
Member
Default variable
it says it varies as load and demand is placed and it is constantly variable the bottom turns i guess its pretty cool looking and everyone i see that posts about them says they "hear" good things and noone has used them for themselves
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Copyright © 2007-2008, Ratsun.net
