Ratsun Forum
Go Back   Ratsun Forum > Datsun Discussion > Trucks
Reply
Thread Tools Display Modes
  #1
Old 11-02-2009, 07:49 PM
84TAVeRT 84TAVeRT is online now
Vehicles: 68 L521, 73 Datsun 620, 04 Tracker, 84 TransAm, 83 nighthawk, 00 xr70r, 00 Triumph 955i
84TAVeRT is on a distinguished road
Default scored a motor and trans today :)
it is an L18 with A87 head, AC compressor, stock hitachi carb, new starter, and fanless water pump...
the trans appears to be a long tail 4spd...
it looks like this one
i got the motor and trans for $160... which is pretty good for oklahoma...
now all i need is a shifter, pivot pin, and short front drive shaft to be able to use this in my brother's 73... then we need a clutch pedal pivot bolt and the plastic bushings that go into the pedal itself...
if you have any of the parts we need pm me...
but hey, we can make some progress now maybe
later,
Chris
  #2
Old 11-02-2009, 08:43 PM
datzenmike's Avatar
datzenmike datzenmike is online now
KING RAT
Vehicles: One '78 KC, two '82 200sx (parts)did own '68 510, '76 B210 (new), '71 521
datzenmike is on a distinguished road
Default
That 4spd should fit the '73's driveshaft shouldn't it?
__________________
RUST NEVER SLEEPS Plenty Of Time For Sleep In The Grave
Quote:
Originally Posted by Skib View Post
Plus I will make fun of anything and everything, just because I can
  #3
Old 11-02-2009, 09:12 PM
Default
Quote:
well i can hope... i was thinkin it currently has a short tail... and that this is a longtail...
  #4
Old 11-03-2009, 01:54 PM
Default
getting an l-series pacesetter longtube header today too...
getting closer...
later,
Chris
  #5
Old 11-03-2009, 03:03 PM
datzenmike's Avatar
KING RAT
Default
Quote:
If built after Oct. '73 your tranny in it should look exactly like that one. Up to Sept. '73 they should be a long F4W63L same length, I think.
Either way can you post a picture of your '73 tranny, if different than the picture you posted earlier?
mike
__________________
  #6
Old 11-03-2009, 03:10 PM
Default
my 73 has one like this (i believe it is the short one)
i know it has the square pan on the bottom... and the driveshaft has the long front shaft...
i had a 3spd auto in it at one point and it used the short front driveshaft...
thanks,
Chris
  #7
Old 11-03-2009, 03:16 PM
datzenmike's Avatar
KING RAT
Default
Crap my info has a hole in it. The bottom tranny is from a 510 and is about 26" the top is from a 610/710 and is 'about' 31.5"
I thought the earliest 620 had the same driveshaft until the long wheelbase trucks came out in '75.
__________________
  #8
Old 11-03-2009, 03:26 PM
Default
i think the one in it now is the stock one...
the engine was still the stock l16 when i got it back in 1993...
we put in a l20b and auto, but the auto didn't like the 4.97 gear ratio very much... and the speedometer was way off...
i will try to take some pics when we pull the trans back out...
later,
Chris
  #9
Old 11-03-2009, 03:50 PM
datsunaholic's Avatar
datsunaholic datsunaholic is offline
Vehicles: Not quite the whole set yet
datsunaholic is on a distinguished road
Default
Yeah, Mike, your info has a hole in it.
The '72-73 620 Manual Transmission used the same transmission as the 510: F4W63, SHORT tail. I've pulled enough '73s apart to know that they ALL came with the short tranny, hence the different floorplate. The F4W63L wasn't used until around '76, and never in a US/Canada truck (dunno about J-series later year trucks). The difference between the 2 is the mounting location and the speedo cog, which is on the opposite side. The case looks somewhat different but both have the square bottom pan.
The '74 trucks used the F4W71B, longtail. However some early '74 models used the F4W63 as you said. I've never seen a stock shorttail '74 though Bleach has. My '74 has a shorttail dogleg in it, but I scrapped a '74 with a longtail 71B 4-speed that was original.
__________________
Well, at least he gets 24 hours notice. That's more than most of us get. All most of us get is, "Mind that bus!" "What bus?" _splat_!
  #10
Old 11-04-2009, 08:56 AM
datzenmike's Avatar
KING RAT
Default
Thank you Doug, all I have is a diagram and it 'looks' like a long tail. So this 'shorty' must be the same as the 510 goon then for gears.
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Copyright © 2007-2008, Ratsun.net
