Ratsun Forum
Go Back   Ratsun Forum > Technical > General Technical
Reply
Thread Tools Display Modes
  #1
Old 10-27-2009, 06:11 PM
Drfixit's Avatar
Drfixit Drfixit is offline
Vehicles: 69 Datsun 521 Pickup
Drfixit is on a distinguished road
Default Head rebuild
My L18 I believe has a bad valve. What should I expect to pay to have the head re-done and what do I need to be sure is included. Can I get new rockers and springs? I know they should be sure the head is flat do a valve job, knurl the valve stem seal opening(Does that sound right?) Performance isnt an issue just reliability. I think A87 is on the head should I look for a completely different head or is it an ok one?
Thanks
Doc
__________________
'69 Datsun 521 w/'74 L18 and 4 speed. Weber 32/36
  #2
Old 10-27-2009, 07:20 PM
athoose athoose is offline
Vehicles: 73 620,80 200SX
athoose is on a distinguished road
Default
Might be cheaper to get a used one.
  #3
Old 10-28-2009, 02:27 AM
zed zed is offline
Vehicles: L18 with v912 head, flat tops
zed is on a distinguished road
Default
You can do most of the work yourself - makes it much cheaper. All you need is a valve spring compressor, valve grinding stick and paste. If the head is not warped, maybe all you need pay for is the new valve seat. New rockers, springs are expensive - I would only replace if they are badly worn. New valves are quite cheap - I lap mine in myself. Check valve stem to guide clearance. Honsowetz says not to knurl guides.
__________________
"Zulu bravo, this is callsign Hotel two five, confirm your name begins with Charlie?...
  #4
Old 10-28-2009, 06:17 AM
Drfixit's Avatar
Default bad valve
Quote:
ok assuming the head is flat I am perfectly capable of taking the valve train apart but doing a valve job yourself? Doesnt that require aspecial fixture or something to kepp the anngle one the vlaves right? Now I have hand lapped valves AFTER the machine shop did the valve job.
As for a used head, again assuming the head is not warped I would like to simply improve on what I have. If I rebuild this head I know what I have.
Keep the info coming please
Doc
__________________
  #5
Old 10-28-2009, 08:29 AM
banzai510(hainz)'s Avatar
banzai510(hainz) banzai510(hainz) is offline
L motor God
banzai510(hainz) is on a distinguished road
Default
a basic regrind shouldnt be to much, 150$
rockers should be put on same lobe where they came from. fi good dont worry about them. have new stem and groind the seats and maybe new guides if worn. When new guides and valve seat installed best to find a shop that knows aluminum as I have seen in Car magazines where the shop didnt heat the head correctly and install the seats and the seat will come out later due to the head shrinking and not being fully instlled correctly.(this can happen to any head rebuilder but just to let you know. All my head have been OK so far as for wear. Most older heaead maybe the seat are sunk in.
make sure that the valves stems are pretty close to the correct height so all the lash pads look even or minor adjustment. mean in on eseat is suck 20thou and the other is perfect. Hopefully the machinist make them all even!!!!
__________________
Throw on some Weber sidedrafts, Rising Sun hood.... call it good
  #6
Old 10-28-2009, 08:38 AM
DanielC DanielC is offline
DanielC is on a distinguished road
Default Valve train is tricky
There are a few issues with a L-series motor. the rockers and cam have to stay together, and you have to keep the rockers in their original position. the valve stem height has to stay very close to the stock position, or it will screw up the geometry of the valve train, and may possibly use up all the adjustment of the valve clearance. Usually, when a shop does a valve job, the valves end up sunk farther into the head. On many engines this can be compensated for, but not so much on the L motor.
Do not get the valve guides knurled They will wear out quickly, and need to be replaced again, soon.
  #7
Old 10-29-2009, 10:14 AM
hang_510's Avatar
hang_510 hang_510 is offline
too ol'skool
Vehicles: 71 2 door - LZ24 / 72 wagon - LZ22
hang_510 is on a distinguished road
Default
Quote:
not unless it was already done, correctly!
you may have to do the same thing to it once its on the bench...
i spent ~$400 on mine w/new seats for larger valves, guides, surfaced not shaved, 3 small crack repairs...
__________________
Quote:
Originally Posted by datsunfreak View Post
"I can spend time working on the Dattos, or wasting money at the strip club. You make the call."
Quote:
Originally Posted by datzenmike View Post
I'll put on chain mail and a dirt bike tire jock strap and drive it!!!!!
  #8
Old 11-01-2009, 06:11 PM
HRH's Avatar
HRH HRH is offline
Vehicles: 1971 510 4 door rally car, 1993 D21
HRH is on a distinguished road
Default
Standard head rebuild around here is $300 if you bring it to them.
__________________
'71 510
'93 D21 4x4
www.mattalbertson.net
http://www.mattalbertson.net/avatarratsun2.jpg
"If Benjamin was an ice cream flavor, he'd be pralines and dick." - Garth Algar.
  #9
Old 11-03-2009, 06:43 PM
Drfixit's Avatar
Default
Quote:
Ok thanks for allthe geat info.I think I amgona start with pulling the head and see what we have.
Mark
__________________
  #10
Old 11-03-2009, 08:15 PM
datzenmike's Avatar
datzenmike datzenmike is offline
KING RAT
Vehicles: One '78 KC, two '82 200sx (parts)did own '68 510, '76 B210 (new), '71 521
datzenmike is on a distinguished road
Default
Quote:
Thanks
Doc
Pop the head. Gaskets are < $25. Pull all valves and inspect them. Keep the valve, valve spring, rocker, keepers etc from each valve position in a labeled zip loc baggy. Probably a lap will fix it up. One new valve is cheap, lap it in put back on with new oil seals... done. Cost:
Gasket.................. $25
Intake valve .......... $19
Exhaust valve......... $12
Lapping compound... $10
Valve seals............. $25? $3 each? I don't know.
Total....................<$100 even less if valve(s) not needed.
Time well spent with your Datsun....... priceless!
__________________
RUST NEVER SLEEPS Plenty Of Time For Sleep In The Grave
Quote:
Originally Posted by Skib View Post
Plus I will make fun of anything and everything, just because I can
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Copyright © 2007-2008, Ratsun.net
