Ratsun Forum
Go Back   Ratsun Forum > Technical > Drivetrain
Reply
Thread Tools Display Modes
  #1
Old 11-02-2009, 09:30 AM
az_rat210's Avatar
az_rat210 az_rat210 is offline
Vehicles: 1975 B210 Project, 78 B210GX Auto Parts Car
az_rat210 is on a distinguished road
Default 5 Speed Conversion B210
75 B210
Current Transmission F4W60 4 Speed
I am obtaining an FS5W60A (80-82 210 5 Speed).
Is this going to be a straight swap?
If I was getting the 76-78 B210 Dogleg then I know the Input Shaft/Spline Count is different for the FS5W63A, as that is a 1"+ 24 Spline shaft.
Reading on the Web the FS5W60A 5 Speed is an 18 Spline 13/16" Input Shaft and the Output Shaft should be the same as my 4 speed. This is the same as the F4W60, so I should be able to use the same clutch. Just drain the oil, pull the tranny and put in the 5-Speed.
I plan to have the Transmission Overhauled before I put it in.
1) Is what I have found incorrect regarding the input/output shafts. Am I going to run into any surprises?
2) Where can I get an overhaul kit. The site I had though I could get one list the FS5W71 not the FS5W60A so it would not be the correct kit.
3) Have I missed anything in trying to plan this out for greatest simplicity?
  #2
Old 11-03-2009, 10:41 AM
Dime Dave's Avatar
Dime Dave Dime Dave is offline
Vehicles: Datsuns and Nissans, Many
Dime Dave is on a distinguished road
Default
The clutch and the drive shaft can be used without any changes.
You may need to fabricate/modify the transmission mount. The 56 series is in a different location. I'm unsure if the 60 4 and 5 speeds are different.
60 series bearings/baulk rings were available from Nissan 12 months ago when I did a 60 re-build. I had the dealer do a "dealer search" to find both bearings and baulk rings to fill my order. Baulk rings may be an issue now, but then dealer stock was the only source. Nothing was being shown in the Nissan warehouse system.
__________________
Dave Patten
www.FutoFab.com
Specializing in composite bodywork for the Datsun 510
  #3
Old 11-03-2009, 02:22 PM
az_rat210's Avatar
Thanks Dave,
That information helps a lot. Tranny mount is the same. The input/output shaft's were my biggest worry.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Copyright © 2007-2008, Ratsun.net
